Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
direct sector by sector scan File Scavenger
you can trial it (but rescue is limited) $40 (not that expensive)
for repair of partition tables Disk Patch also $40
its generally recommended you rescue first then attempt repairs
I find it unlikely he deleted his system partition but in the event that was done from outside of windows somehow fixmbr
note > If an invalid or nonstandard partition table signature is detected, you will be prompted whether you want to continue. If you are not having problems accessing your drives, you should not continue. Writing a new master boot record to your system partition could damage your partition tables and cause your partitions to become inaccessible.
