FueledByMusic
- Aug 18, 2006
Ok so my PC is down for a few days. So i figured since I can't use it I'd tinker with it. I have some "Testors model spray paint" and figured I'd try and use it on my keyboard and mouse. I was just wondering if you have to rough up the surface before painting like you would with metal or can you just clearn and spray?
