Jun 18, 2009 #1 D DeFex [H]ard|DCer of the Month - June 2011 Joined Feb 13, 2001 Messages 5,248 From what i can tell the only difference is that the SE does not have SLI, is that correct? because i dont need it, and would like to save $40 or so
Jun 18, 2009 #2 B Bigbacon Fully [H] 2FA Joined Jul 12, 2007 Messages 22,714 do a quick search, I definitely recall there already being a thread on this
Jun 18, 2009 #3 Z Zero82z Fully [H] Joined Jan 20, 2004 Messages 27,897 The P6T has SLI support, an onboard reset button, and two more SATA ports run off an external controller. Those are the only differences as far as I can tell.
Jun 18, 2009 #4 D DeFex [H]ard|DCer of the Month - June 2011 Joined Feb 13, 2001 Messages 5,248 Bigbacon said: do a quick search, I definitely recall there already being a thread on this Click to expand... no it was between the P6T deluxe and the P6T you could save wear and tear on your keyboard by not typing anything if you have nothing to say. thanks Zero82z for a helpful reply, that is what i was hoping for.
