p67 sabertooth cpu fan speed control not working
kandor
Hi,
I have an H70 on this mobo cooling a 2600k, as the h70 says, I used the supplied Y cable to connect both corsair fans to the cpu fan header. Then in bios I set cpu fan control on, standard profile etc. Yet the fans both run at full speed all the time no matter what I set the fan control to the fans are spinning 1900 rpm or so, too loud. I didn't want to use the included 'resistor' cables to slow the fans, I'd rather have the mobo do it - but it ain't working!
I am having a similar problem on my P7P55D (non-E, non-Pro, etc) and would appreciate some insight on the topic as well.
I think it may be because it's only a 3-pin connection on the fans?
It's def important to have fan control if you are overclocking :(
The 3 pin fans are controllable by the mobo. It changes voltage to reduce the speed.
I now have it working, but for some strange reason it would only control the 2 corsair fans (connected by h70 Y cable) when I plugged it into the chassis1 port NOT the cpu port. Whenever I plugged them into the cpu port they just ran at full speed regardless of qcontrol settings.
So, I plugged the pump into the cpu header and disabled qcontrol on that - it runs at a constant 1400rpm. The 2 corsair fans y'd into the chassis1 header with custom speed control works great, they spin at around 1200 rpm (totally quiet) at idle at 1900 rpm at load.
The assistant fan is doing around 2500 at idle upto over 5k rpm at load.
So, basically my computer is totally quiet about 90% of the time and noticeably louder under full load like prime95, rendering etc.
It's just weird that the fans wouldn't work right on the cpu header.
The mobo CPU Fan Header is PWM 4 pin and I have ran into a few boards that will not control a 3 pin fan. It sucks becuase I really loved my 1,900 RPM S-Flex when it was controlled correctly.
that's interesting - their manual makes no mention and the chassis1 header is also 4 pin but has no trouble controlling my 3pin corsair fans where the cpu one wouldn't.
Just checked and the sabertooth p67 manual shows the pinout for both cha1 and cpu header as identical, but it seems they are not.
Bump. I hope this can be fixed in a bios update. It's annoying hearing one of my fans (dual fan cooler) running at 2100rpm all the time. I'd like them both running 1600rpm idle. I know I have a y-connector somewhere so I guess I'll have to go find it for the time being.
Thanks for the update Kandor. I've been having the same problem since yesterday when I got my new H70 (also using the same mobo). The only solution I could find at the moment was to switch to 2 other low rpm fans instead of the ones supplied with the h70. Although after your update I think I will change back just to see how it works out, thanks again!
