p5w-dh cpu installation problem...HELP!
ipam45
i just got my P5w-dh today and i;m really happy so i got everything set up and i get ready to install the cpu. when i put the cpu into the socket everything was fine. but when put the little metal cover that sits above the cpu, it;s sticking up a little bit. then i try to put the clip in and that;s when i realize that there is too much resistance, and it;s cause by the edge of the curve in the cover. i;m afraid to break my new conroe so i stop doing everything and posted on here. even thou you can see a little scrached marked on the cpu but i don;t think it;s broken. should i send the mobo back for rma? i don;t know if this is normal of not, my first build and i;m pretty nervous.
thanks
I think your fine its supposed to have some resistance, to hold the cpu in place.. :)
so i should just press away!? my mom use to build computers when 486 was the best computer there is and she said i should just stop being a pussy and press down. another question, it;s is normal to some some curvature on the metal clip?
Listen to your mom and stop bein a pussy LOL........... (Hoping you have everything installed correctly) which metal clip? the bracket that holds the cpu in place? :confused:
yes the bracket or the "load Plate" it has a little curve in the mid section of it on both side, which creats a pressure point on the cpu. it;s looks too uniform to be an accident. but i still don't know what i should do. did you notice taht with your motherboard?
i;m good now, my dad came back and took one look at it and said it was a pressure socket and taht's the way it's suppose to be. he's a electric engineer but i didn't think he knew anything about computer :p .
thanks for all your help anyways.
it's probably broken now. hehehe. j/k.
it's like a retention device for the processor and i agree that it seems a little bit too tight.
Yeah, it's a tight squeeze. When i was putting mine in i thought it was a bit tight, but didn't see any other way to get it done. I mean it's just a little plate with hinges, kinda hard to get that mechancailly messed up i thought. I was most worried about dropping the damn processor or something... I had waited five weeks for the processor to arrive so was super nervous about damaging it. Probably would've taken another five weeks to get a replacement... :eek:
LOL
thats great..
hope it all worked out for you
