p5n-e sli HD activity light on constantly
Hey guys, my HDD activity light on my antec 900 case is constantly on, this is a p5n-e sli mobo. I've been having problems for a day now with this machine, mainly a memory module went bad. I just wanted to know if this is something to worry about. The indexing service is disabled, and the process is not running. The light is on solid from the time I start the computer, and never flickers.
Any ideas?
bad axe 2's have the propensity to do this as well. i wouldn't worry about it; listen to your drives and see if they are actually in use. most likely, they are not. you could always build a seperate circuit that blinks the hdd light intermittently to make it look like it works, if it bothers you :)
Well the thing is it was working, and now it isn't, i assume that's what was happening to the badaxe2's also?
The HDD Activity light works just fine on the badaxe 2 as long as you leave the second sata controller enabled
I found the problem, my P-ATA cable hooked to my optical drive wasn't plugged in all the way. Thanks for the help :)
interesting... thanks for the info. unfortunately i have no use on these machines for a secondary sata controller, other than taking up extra adress space and such.
i have been very curious as to why this was happening, that gives me a little more data!
