p4 2.8 boot problems
alobor
in bios it says frequency is 1.4ghz is that right?
Im getting a cpu has been changed or unworkable screen.
the boot screen say
main processor p4 1.4
cpu brand name p4 2.8
What should I do? everything was running smoothly until I rebooted. Just before I rebooted AVG antivirus detected a trojan dropper.delf.cx Could a trojan do this to my computer??
Thats right, 14 is correct. Do you have a motherboard that supports it? I have a 2.8c and I have it at 238 FSB and it runs at 3332 MHz. Again, do you have an 800 FSB motherboard?
ic7 - 800mhz.
I pulled the battery & that seemed to work. I however still have this damned virus..
Virus. Well do a low level format and a fresh install of windows and you should be fine then.
