D
Deleted member 21895
Guest
All of those punch-cut fan grills need to go! All they are good for is increasing turbulence (more noise) and restricting airflow.thrawn86 said:http://sarversystems.com/index.php?option=com_expose&Itemid=31
select past projects - p180
All you need to know about cooling the p180. The lower middle 120 is optional if you do the lower front 120 mod (and not recommended if you have HDs in the lower cage or a longer psu)
Unknown-One said:All of those punch-cut fan grills need to go! All they are good for is increasing turbulence (more noise) and restricting airflow.
