So there's a long backstory to this but I'll sum it up. I got a cheapie celeron 667 in a dead system from a relative that got me looking for a mobo. I got a deal on a new Acorp 6a815epd for about 35 shipped, so figured why not. The 667 was a reluctant overclocker, but I found a celeron tualatin 1.4ghz on it now (just found one for 39 and said why not). I hit the max w/o going to 133mhz fsb the other day doing 1.6 ghz with no voltage increase (through the bios fsb settings, which only let you go to 115mhz with an overclocked PCI bus to match), seemed stable, I want more.
Now the mainboard has jumpers to set FSB, wth 4 settings. 66, 100, 133, and auto. I tried it a long time ago with the celeron and it appeared to be a useless jumper (no effect), but now that I got the 1.4 celly you can step it down from 100 to 66 but not up to 133. BTW I'm using the Lin-Lin tualatin adapter, the mainboard can support coppermines but not tualatins due to the voltage. The chip is properly detected as a 1.4ghz part.
Anyone know of a way around this auto detection that I'm missing?
If you need it, the manual is here:
http://www.acorp.com.tw/download/Manual-download/intel/6a815epd/6a815epd.zip
