overclocking Pentium 4 2.4c HELP
kevin525
hi all, i got pentium 4 2.4c (800FSB), with corsair xms 1gb of ram and try to overclock it to around 3.0c i am using ALBATRON motherboard, can some one give me some advice what setting should i change it to in BIOS, like what multi... and what voltage, by the way my 2.4c is retail and i also bought a vantec fan heard is pretty good, thanks
i have never heard of albatron
move your fsb up in 10 - 10 - 10 - 5 - 5 and then 2 incraments
Well, you can't change the multi, So change the FSB, 250 is about the basic for an intel oc. But depending oin the speed of your ram you will need to run a divider, if it's unstable five it more volts
