Seahawks_Fan
- Feb 21, 2009
I recently bought the 8500 and P5 Pro, and I am trying to get the 8500 overclocked to 4 Ghz. Whenever I set the Front Side bus past 415, the overclock fails Linpack/Intel Burn Test. I am running Windows XP 32 bit w/ 4x1 GB of RAM, system sees 3 GB.
This is what I have set in BIOS:
CPU Ratio: Auto
FSB Freq: 410
PCIe Freq: 100
FSB Strap to NB: Auto
DRAM Freq: 901 MHz
DRAM Timing: Auto
DRAM Static Read Control: Auto
DRAM Read Tuning: Auto
Mem. Overclock Charger: Auto
AI Clock Twister: Stronger
AI Transaction Booster: Auto
CPU Voltage 1.275000 Volts
GTL Ref: Auto
PLL Voltage: 1.54 Volts
FSB Termination Voltage: Auto
DRAM Voltage: 1.90 Volts
N. Bridge Volt.: Auto
So. Bridge Volt.: Auto
PCIe SATA Voltage: Auto
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIe Spread Spectrum: Disabled
CPU Clock Skew: Auto
N. Bridge Clock Skew: Auto
CPU Margin Enhancement: Optimized
CPU Configuration
Ratio: Auto
C1E Support: Enabled
Max CPUID Value Limit: Disabled
Intel Virtualization Technology: Enabled
CPU TM Function: Enabled
Execute Disable Bit: Enabled*
Intel Speed Step: Disabled
Intel C-State: Enabled
My temps are OK. I'm using Xigmatek HDT-S1283 to cool the CPU.
Also, the Idle CPU temperature is always 102 degrees Fahrenheit, even when the mobo and CPU are running at default speeds. Always the same high idle temp. Why???
I thought it would be somewhat easier to get to 4 GHz with a CPU like this one w/ 9.5 multiplier. When I go higher than about a 412 FSB frequency the PC fails IBT.
Is my CPU voltage too low? I read that these 45 nm CPUs should not be overvolted like the 65 nm chips. They are damaged by overvolting more easily.
Thanks in advance for any replies.
CPU Ratio: Auto
FSB Freq: 410
PCIe Freq: 100
DRAM Freq: 901 MHz
DRAM Timing: Auto
GTL Ref: Auto
CPU Configuration
Ratio: Auto
