flooberjobby
- Apr 4, 2008
Ok so I have a Core I7-950 currently @ 3.79 on the stock cooler at 61C all 4 cores. HT on.
I have a XFX 6970 @ 925 Core, and 1450 memory.
Room temp 72F degrees
System Specs.
12 Gig DDR3 @ 2200mhz
2x 1TB Raid 0
Asus Rampage III Gene(means the Micro ATX version)
Core I7-950 @3.795 Idle temp 61C (load no more than 88C)
XFX 6970 @950 core 1450 memory Idle temp 60C (load no more than 80C) Voltage set to +20 in CCC
I can't even play CSS at higher settings than 2560X1600 Everything on high/very high. full HDR, color correction, 2x AA, 16 AF, with MLAA on full. No V-sync @ 63.5 FPS in the stress test. Which interestingly enough doesn't dip below 55 in intense situations. Am I hitting a memory limit once I go above 2x AA? I know it wouldn't run as smooth with 2xAA before I OCed my video card.
When I overclock the core on the video card to 950, my games freeze/crash. Any hints on how I can rectify this?
I have a ZR30W(2560x1600 30 inch Monitor) That I game with, as well as work. And I'm just trying to get the most out of my system.
Any help would be greatly appreciated
Note: Nooby overclocker.
System Specs.
2x 1TB Raid 0
