Overclock 6200 Help!
jh0n9
yes...umm i have a 3d Fuzion geforce 6200...and wants to overclock my video because i want to increase my fps in CS Source...first of all..i already have coolbits registered..and i have riva tuner.....
I dont know but....i putted my core clock to 355 MHz...and whwnever i play cs source...i get these black stuff all over the place...but hwnwever i put it to 353 its fine...why cant i overclock higher?...i saw some people even go over 400 MHz with their GF 6200....well i can only do that to my Memory Clock which is 523 right now...i tried unlocking 4 extra pipelines..but my video card cant do it..guys help me...i need to raise my core clock? why is it like this...
Wow, I already feel depressed from reading this...
Back OT, not all 6200s are cherry picked. You might need to pick up a very cheap aftermarket cooler on Newegg (it'd be a lot better than the stock HSF.) Also for CS:S, increasing FPS, I'd recommend using Casey's Config.
Black everywhere (and distorted environments) is a typical graphical corruption seem when a video card errors in a Source engine game. As Stryker said, getting a better cooler (does yours have a fan or is it passive?) will allow you to take the card further. If you dont want to spend the extra cash, or even in addition to getting a new heatsink, software tweaking is always good. It's also a good thing that the Source engine takes so kindly to it :D.
yes..i have a fan..and can u give me a website that shows how to tweak ?
www.tweakguides.com has a great guide on tweaking the Source engine (its for Half Life 2, but the tweaks apply to CS:S as well). Also, casey's config which stryker linked to in post #2 is a neat little file that should help raise your FPS a good bit.
hey..i need a config that is pure performance...they said casey's config is balanced between performance and IQ....i need a pure performance one..does anyone know any?
