I'm running a Venice 3000 on an A8N-Delux, I recently went ahead and decided to over clock from stock 1.8GHz to 2.7GHz. I successfully over clocked to 2.7 using a multiplier of 9*300 at 1.52VCore. I set the ram to Auto which is running at 5332@266Mhz. For some reason I've been getting hiccups during dvd playback, gameing, sound playback. This never happened before the overclock where entire programs stall for a slight second. My question is, is my over clock safe or am I missing something I should change? I also noticed other options within the bios that affect my pci express rate, could this be the cause of the stalls? Any help or incite towards creating a solid OC would be appreciated. Thank you.
