delusion_2005
- Mar 8, 2005
I am planning to to build a new pc, i have decided to get a Intel Pentium4 3.2ghz HT LGA 775 with Giga-byte 8I915P Duo Pro, will i have any overheating problem like, computer automatically reboots?
delusion_2005 said:I am planning to to build a new pc, i have decided to get a Intel Pentium4 3.2ghz HT LGA 775 with Giga-byte 8I915P Duo Pro, will i have any overheating problem like, computer automatically reboots?![]()
freddiepm61 said:you probably will with the stock cooler, and even if it does not it will be very bad for the cpu, as it gets so hot........
Get a zalman 7000, is cheap and easy, and will cool very well, and much quieter than the intel one. will also be better for cpu.
freddiepm61 said:very loud, and by just fine, >60degrees c at load?
with the 3.8ghz, they often turn off with the stock cooler.
>60c is shocking.
