OSX Console help
use the tag -configonly and under advance option tell it you want deadlines.
I right click bring up the info
then after it looks like this
fah -configonly
Wicked
ok......you want to open up terminal (applications\utilities)
navigate to the folder it is in using the CD command
then enter the command ".\fah5 -configonly" (without qoutes)
if this sounds completely alien...tell me where it is at (ie desktop) and i will give you exact directions
It doesnt sound that alien almost like dos. Cant figure out the path to my desktop though!
FAH console is right on my desktop
Thanks, Mark
ok...yea...it is like dos.
so when you open up terminal type:
cd Desktop
.\fah5 -configonly
and that should run the config again.
