Red Squirrel
- Nov 29, 2009
I am building a large storage server (24 bay + FC card with around 50ish drives, though those will rarely be turned on). This server will be 100% dedicated to storage, and possibly ldap/kerberos as I want to experiment with that for better file security, but for now it's only going to be strictly storage. So NFS, Samba, possibly iSCSI. I will be using mdadm for the raid arrays.
Anyone know some good tips for optimization? I know I can set the rebuild times to be faster. How much faster is too fast? This is a fairly beefy machine. Xeon E3 1230 V2 Quad Core Processor 3.3GHZ, 8GB of ECC ram. So may as well put those resources to good use.
Also, what about chunk sizes when setting up an array, what is the general rule of thumb here? If mostly bigger files (Ex: VMs) then bigger chunk size, if more a mix of files, not as big of a chunk size? Is there a magic value that is all around good? Most tutorials seem to say like 32 or 64. What if I jack that up to like 512, 1024? higher?
Any other goodies I can optimize? Also, I will most likely read up on NIC teaming and team both gigabit nics. I have a managed switch so it should be able to support it. Any optimizations I can do on the network side? This will be a file server and not a SAN, so it's going to be on the same network/vlan as everything else.
