I'm building a file server for a college dorm, and the bandwidth that each room in the dorm gets is gigabit which I think is limited by the cat 5e cables my dorm uses, and every connection in each room is hooked up to just a large switch down in the basement.
I'm trying to maximize bandwidth here and I'd rather put the file server in a room, and I would have access to more than one ethernet ports. Is it advantageous to get a multiport NIC and just run cabling from like 4 different rooms? Or would it be loads better if I somehow just put it in the basement and directly hooked it up to the switch?
