Opteron 170 Cooling
Patman
Would it be worth it to setup a watercooling loop to get good overclocks of 2.6 or higher out of an opteron 170 or should i stick to the zalman 9500?
I got mine to 2.6 on air with no voltage adjustments. YMMV, but I don't think you'd need water to reach 2.6. In fact, you could probably get up to 2.8 on air with decent temperatures. Especially with the CNPS9500.
ok; whats the best aircooling solution and how does water compare.
i got 2700 out of mine easily, but i have water on the way anyway...
so really decide if temps or my proc are limiting my oc then decide. Whats about the max temps of these procs?
