videodrone83
- Jan 30, 2006
Okay my current choices Ive considered
The Scythe Ninja
The Thermaltake Big Typhoon
The Zalman 9500
Now I currently have a cooler master hyper 6, but on this socket 754 I get like 50C on the cpu, which seems high to me, I dont know if its correct or not, its a MSI Neo Platinum S754 board, I can always use what I have now but the temps seem kinda crappy.
The Scythe ninja, looks like a decent cooler, doesnt look much different from this hyper 6, is it much bigger then this hyper 6?
The Thermaltake Big Typhoon I dont really have any quirks with, its a good consideration of mine, and I would pair it with a nexus or yale fan.
The Zalman I kinda like, I've never owned a zalman hsf before, Ive seen some pictures with the fan and heatsink twirled around in a different direction, is this possible? also is it possible to disable the blue led that comes with the fan, or put a red led on it?
Ive done some research so far on each HSF, but most sites are bias? can someone post their temps or their own considerations on a hSF, maybe something else I have not listed that does a better job?
My new machine btw will be an opteron 146 with dfi ultra d board
The Scythe Ninja
The Zalman 9500
