Operation help the noob
kandah
I have read 4-5 different guides on OC'ing but since this is my first time and im very afraid to ruin something im asking you guys. How would you proceed with overclocking if you had my system?
CPU
Intel Core 2 Duo E6600
Motherboard
Gigabyte GA-965P-DS3
Memory
Corsair TWIN2X 6400C4 DDR2, 2048MB CL4
Graphics Card
XFX GeForce 8800GTX 768MB GDDR3
Hard Drive
Western Digital Raptor 150GB SATA 16MB 10000RPM
Sound Card
Creative SB X-Fi Xtreme Audio
Power Supply
Corsair Powersupply 620W
Case
Antec Performance One P180 Miditower
CPU cooling
Scythe Infinity
GPU cooling
Stock
Case cooling
3 x ANTEC TRI-COOL 120, 1 X Noctua NF-S12-1200
When I first started I had it @ 3.4ghz but it was unlinked so I didn't have the 1:1 ratio many people talk about...decided to do 1:1 so I can be like everyone else :)
I lowered my multi to 7 so I could get the required 1:1 ratio
Well here are my settings using a E6600 + 650i + Firestix
CPU voltage = 1.37
Memory voltage 2.08
Northbridge voltage 1.739
FSB = 475 (or 1900 as it says in the bios...1900/4 = 475x7 = 3.325)
Memory = 475 (x2) = 950 @ 4 4 4 12 2T
Don't know if that explains anything but those are my settings...what you should do is this
To get 1:1 you need your FSB to be 400 (400x4 = 1600 or 400x9 = 3600)
I don't know if you want to oc to 3.6ghz so lower your multi to 8 (stock is 9)
Put the FSB to 400 which will get you 3.2ghz (400x8 = 3200)
Memory should be running @ 400x2 = 800 so that's 1:1
Try to do this at the stock voltage (1.325). If it freezes go back and increase the voltage until it's stable
