Feb 12, 2004 #1 G Gibson Weaksauce Joined Feb 3, 2004 Messages 106 I uninstalled Windows Picture and Fax Viewer. It's not on the install disk to install alone. How can I get it back without reinstalling?
Feb 12, 2004 #2 J jpmkm That Ain't Mayo On My Lip... Joined Oct 30, 2001 Messages 5,772 What version of windows are you using? It may be in the add/remove programs control panel under windows components or something like that.
Feb 12, 2004 #4 CommanderFrank Cat Can't Scratch It Joined May 9, 2000 Messages 75,399 Look in your Recycle Bin...it may still be there according to your settings. If the files are still there, just restore them.
Feb 12, 2004 #5 G Gibson Weaksauce Joined Feb 3, 2004 Messages 106 Nah, it's empty. Doesn't go there when you uninstall stuff anyways
Feb 12, 2004 #6 CommanderFrank Cat Can't Scratch It Joined May 9, 2000 Messages 75,399 Yeah I guess you're right. I use Norton SystemWorks and the Recycle Bin is protected until you flush it within the set time period. Haven't used a standard Recycle bin for years
