only found as an bb intel system?
Imagenyuss
I've been looking to get soltek's EQ3401 *case only* but so far I've only found it in barebones systems. I like the look of the case, but I'd like to build the rest of the comp on my own.
I used froogle in my searches; if anyone is able to find the case by itself, I'd adpreciate it.
tia,
-micah
I think its just the motherboard and power supply that is included, you add the rest...
Since its small form factor, you can't just buy a powersupply or motherboard that will fit off the shelf.
