Hey I got a question for hard forums and I would appreciate your advice. I plan on buying crimp sata power connectors from frozencpu.com along with some uv sleeving. My plan Is to use cable from an old power supply to make one long custom cable for my antec 1200. I was thinking of putting 12 connectors on the 1 wire. Is there any negative to this? Would the guage of the wire be sufficient enough to power. 12 devices if I were to hook them all up? Thanks for any advice...
Edit: power supply is corsair tx750
