I unfortunately purchased an old XBOX360 from a so-called friend. The XBOX360 does not have an internal wireless card so I have to buy a network adapter. I looked around the web and I guess I have to buy a specific type of network adapter specially made for the XBOX360 which runs around the $50-80 range. I mainly wanted to use the XBOX360 to stream movies from my Synology Network Attached Storage (which I haven't learned to configure yet). Currently, I can stream movies from my PC via Windows Media Center (whenever I hook it up via ethernet and bridge my PC's wifi connection).
My problem is that in order for my XBOX360 to get network access, I have to input an ethernet cord which is in the way of everything and bridge my adapter.
I was thinking of purchasing something that would be wireless that I could move around to be close in proximity to my XBOX360 so I could plug an ethernet to it. The router is in the living room and my computer and XBOX360 are upstairs in my room. I felt like a Network Adapter for the XBOX was a waste so I'm thinking Access Point or Wireless Repeater.
Do access points have to be physically connected to the router? Can I plug my XBOX360 into the wireless repeater like I would to a router? I was thinking of a repeater as it could possibly boost the signal for my PC upstairs as well.
I bought this network adapter for the XBOX360, it didn't work.
NETGEAR WNCE2001 Universal WiFi Internet Adapter
http://www.amazon.com/NETGEAR-WNCE2...8&qid=1362539755&sr=8-5&keywords=access+point
I bought this repeater to extend my range, it would drop connection within 2 minutes.
Anker Uspeed Wireless-N Wi-Fi Repeater Access Point Range Extender 300Mbps
http://www.amazon.com/Uspeed-Wirele...40166&sr=1-1&keywords=anker+wireless+repeater
I have a Netgear 108Mbps WGT624 v4 router and a D-LINK DIR-601 router that I was thinking of converting to APs but I was looking at the DD-WRT guides and these routers weren't supported I think.
