R
ring.of.steel
Guest
^^^ for like 20 meters
cheers guys
cheers guys
also, STP cable is a must..... unless you want something to blow up if it ever gets struck my lightning.
also, I would run it across two houses, I would anchor it to the side of the house all the way to the ground, dig a small trench, insert PVC and run the cable through the piping with proper couplers to keep moisture out.
EDIT: Also, there are some cables that come with separate grounding wire.....I would seriously consider that.... then again, im not a cable guy per se.. so take what i say with a grain of salt![]()
If something gets struck by lightning, it doesnt matter what its made out of, or how much sheilding it has, things will get toasted.
