Due to a multitude of problesm, I have been forced to reinstall Win2K a number of times.
I have two HDs, one that I use for OS and programs, and one that I use for data.
On top of the floppy, I also have three removable media drives: a CD burner, a DVD burner, and a Jazz drive, which I despise.
To reinstall, what I have done is to delete the primary partition; recreate the primary partition and make it active (only one primary partition); and then setup using the bootable Win2K CD.
Usually, the three removable media drives are enumerated consecutively as E, F, or G -- that is, if the setup goes right.
The correct letter assignment should be:
A: Floppy
C: Primary partition (NTFS)
D: Non-bootable partition (Fat32)
E: DVD Burner
F: CD Burner
G: Jazz Drive
What I get sometimes is:
A: Floppy
C: Non-bootable partition (Fat32)
D: DVD Burner
E: CD Burner
F: Jazz Drive
G: Primary partition (NTFS)
In reading the MS Knowledge Base Articles, it should not do this. It should first look for the bootable, active primary partition and assign that to C:
Anyone have any clues as to why this might be happening? It is a bit of a nuisance to me.
A: Floppy
E: DVD Burner
F: CD Burner
G: Jazz Drive
A: Floppy
D: DVD Burner
E: CD Burner
F: Jazz Drive
