FlatLine84
- Apr 7, 2005
Get this one guys, it's new to me... Had a PC that was having issues with staying running, it would boot, then just shut off. My first thought was heat, but the PC was clean and in a very cold room. It's actually a firewall and stays running all the time. So I went over to take a look at it, and it sounded like a head crash almost, so I brought it back to the office. Upon further investigation, I noticed the sound was actually coming from the PSU. I removed it from the case, and turned it on using a wire. Really strange noise, high pitched, and it fluctuates as well. So I was well, just a bad PSU, swapped it out with one that I was just using in a test rig. Being the idiot I often am, I hooked everything back up, instead of the mobo first and booting. Well, the machine started to boot, then the PSU started making that noice again, and I couldn't get the machine to stay running. So it looks like some other piece of hardware caused the PSU to die, and because I was a putz, I didn't isolate what the culprit was. I'm assuming it was the mobo, as there is only that and a hard drive, everything else is onboard.
