I'm sure I will.BeernuT said:I like mine. Hope you like yours.
-bn
I think they look tacky.aZn_plyR said:but who needs long cables for hiding when they look so DAMN good....
_Korruption_ said:I think they look tacky.They barely bend around corners, I had a lot of fun wiring up a Modstream 450W inside a TT Tsunami...
jonnyGURU said:I sort of did a speed read, but I don't see how it "didn't fair well" other than exhibiting a 5% differentiation on the 3.3V, 4% on the 5V and only 2% on the 12V in going from 93W to 502W versus a 3% differentiation on the 3.3V, 2% on the 5V and 2% on the 12V the Antec exhibited when going from 92W to 498W. Either instance was within the +/- 5% specification.
Sure, that means the Antec has tighter rails, but that's a power curve your PC isn't likely going to make. Even if it did, the 3% or 5% change in voltage would not be sudden and would likely have no effect on your hardware whatsoever.
What I see is the OCZ ran cooler and apparently at a higher wattage (although ONCE AGAIN the writer chose not to itemize their loads. He states the Antec went up to 530W and that the OCZ was loaded to the tester's "35A peak load" on the 12V, but didn't break down anything else.) The OCZ also ran at better efficiency at the wattage 90% of our PC's are going to be at under "normal usage" (between 200 and 300W)
Or is it the Power Factor your looking at? Because the OCZ doesn't have Active PFC.
I do think the Antec is better made, but I don't think it's fair to say the OCZ didn't fair well. The TTGI... THAT didn't fair well. 7% fluctuation on the 3.3V and 5V? Yikes!
The Enremax showed an average of a 5% fluctuation going from 98W to 463W and held a > 80% efficiency. Not too shabby.
I really wish these guys would break down their load, because it does matter what the 5V rail is loaded at while the 12V is loaded at 35A because a 5V rail that can't do more than 10A while the 12V is loaded up to 35A doesn't do me a whole hell of a lot of good, you know? And telling me wattage doesn't help. Case and point: A Thermaltaake TWV480 can do 480W... Just not where I need it to!
aZn_plyR said:well.... extremeoverclocking.com did a new review on this psu....didn't do very well either![]()
http://www.extremeoverclocking.com/articles/guides/Power_Supply_Testing_5.html
this is the chart comparing its results to others.... I am just glad I grabbed the truepower 2![]()
