OC'ing m xp 2500
Whimpy
Well i been pushing my little mobile along to 2400, prime 95 stable, but tems get get to 58 c.
for HSF am using http://www.newegg.com/app/ViewProductDesc.asp?description=35-106-603&depa=0
I know not the best but $$ is tight, is there any other HSF that are on the cheap (less then $30) that will keep this beast down to a respectable temp.?
Mobo is NF7-S, 512 stick of mushkin green label 3200 ram, and fx 5500 oc along with dual WD sata 80's. case temp idle is at 28 c, load jumps up to 32, idle cpu is at 40 c but isnt that a bit to high? I am thinking pushing 60 c under load is a bit high, so I might have to back down on my OC... Any sugestions will greatly help.
