OC issue in x64
Willsonman
So I can overclock to 2.7ghz on my windows x86 platform but I can only get to 2.46 or I get a BSOD in x64. Kind of annoying really. All drivers are up to date and BIOS is as well. ANy thoughts or suggestions? See my sig for system setup.
Uhm... thanks? wow that was a really pointless statement. anyways on to more enlightening things. If I set my memory divider and voltage at the right spot for 2.7 I can get into windows but for some reason the multiplier changes to 5. I can adjust all the settings up to 2.7 with clockgen just fine... funny that the BIOS will not make it work right on booting.
XP64, actually running 64 bit code, is harder on the cpu than running it in XP32....my normal overclock of 2.6 has to be ran down to 2.5 under X64 to get the rock solid stability....
Well I guess I'm just lucky. My overclock went up when I switched to x64. Although not by much.
