oc fx-53
magoo
Id like to try to goose my fx-53 to fx-55 speed. I have everything stock speed on an A8V deluxe ASUS board with an Antec true 480 and air cooling from an AMD HSF. Any suggestions???? id like to do it with the fewest adjustments possible??? thanks ahead of time.
The easiest adjustment free way is to bring up the multiplier one spot to 13x from 12x, and I'm assuming adding some voltage. Just download Prime95 and run the "SmallFFT" torture test and if it errors add more voltage until it doens't ;) That is as long as your CPU doesn't get too hot.
only a 200mhz boost..hehe should be easy...and yah, just bump the multiplier to 13x like tsue said..and a lil more voltage if it's unstable..it's not that hard hhee
