Hi. finished choosing all the parts for my rig, but everyone that hears I picked the 3470 over 3570k tells me I did a mistake, and that a non-overclocked i5 won't be able to do much.
I did not order the parts yet, so there is time to change things.
I will be gaming mostly, recording gameplays alot to my HDD using dxtory/fraps and rendering the files with vegas (sometimes!). other than that? not much.. surfing the web maybe.
Will CPU OC benefit me? do I really need it? If I choose to OC I'll have to spend like extra 200$ for a good mobo and a CPU cooler..
Current parts I picked are these (no-overclocking intended):
Intel Quad-Core i5 3470 3.2Ghz 6MB Tray
ZALMAN 7000V Al SI EDITION
Gigabyte GA-B75M-D3H or ASRock B75M
Hynix 8GB 4GBx2 DDR3 1600 CL11
Intel SSD 120G Sandforce 2281-330 Sata 3
Seagate 2TB Barracuda 7200RPM 64MB 1TB PLATTER
SAPPHIRE 7970 3GB GDDR5 HDMI RETAIL
Seasonic ECO 600W
If I want to have an overclocked machine that fits my budget I'll have to choose this:
Intel i5 3570K : IVY BRIDGE, CORE I5, S1155, 3.4Ghz - TRAY
Scythe MUGEN III REVB
ASRock Z77 PRO3
TRANSCEND 8GB (4GBX2) DDR3 1333 CL9
GIGABYTE HD7970 "WINDFORCE 3X" 3072MB GDDR5
ENERMAX NAXN 550W
SEAGATE 7200.14 1TB SATA3
Had to give up SSD, lose 1TB of HDD space... and it crossed my budget limit by a little bit... is it worth it?
Which one of them will be better for serving my needs? maximum gaming performance and being able to record/render gameplays sometimes with no lag?
Thanks a bunch!
Seasonic ECO 600W
ASRock Z77 PRO3
ENERMAX NAXN 550W
Thanks a bunch!
