oc and cooling problem
asuka10456
First of all my specs are
e6300 w/ scythe infinity
p5b deluxe
2 gb set of ddr2 800 g.skill hz
2 x 36 gb raptors
250 gb seagate hdd sata2
xfx 7900gt
plextor p760a
400w forton blue storm
Aspire X-CRUISER link to case http://www.newegg.com/Product/Product.asp?Item=N82E16811144151
My temps are about 46-47c idle 58c load @ 3.6v and 2800mhz, i had it at 3200mhz 1.4v about a few degrees hotter but when i ran orthos after a hour or so my pc would just reset and the hottest it got was 62c. I montior temps using Intel's TAT
Things i did to try to get my case cooler:
I took out the 80mm exhaust fan and replaced it with a 120mm yate loon,
took off the vent on the window cause it wouldnt fit with the scythe infinity,i added a 80mm fan where the vent was but it still wouldnt fit with that little fan on there(the hsf almost touches the side window) so i unscrewed the plexiglass and flipped it over so it would fit. and attach the 80mm where the vent was on the window. I tried reseating the hsf but i still have about the same temps.
So now i don't know what to do to get my temps any better. I always see people post there oc results with worse cooling and get better temps than me. I think it may me getting a cheap case that caused this problem since it is alittle cramped and possibly has bad air flow.
Any advice would help and a explanation of why my pc resets when running orthos cause im sure i seen worse temps while running it and never heard of it resetting the system.
Thx in advance for any help ^_^
ALSO i maybe buying a antec p180 case from a friend and am wondering will it really help with my temp problem but i don't really want to consider it a solution.
