HardOCP News
[H] News
- Dec 31, 1969
If you are in the market for a new case, check out this review of the NZXT Phantom 410 mid-tower chassis posted at eTeknix today.
A mid tower form factor gives NZXT less room to play with when designing their case. You would be wrong if you assumed that this space constraint would force the Phantom 410 to cut down on features. It possesses 3 tool-less internal 5.25” bays, 6 internal 3.5/2.5” bays, 4 of which are located in a removable cage and 7 PCI expansion slots. Cooling comes in the form of a single 120mm intake fan and a pair of exhaust fans, one of which is 120mm, the other a 140mm LED version, located in the rear and top mounting locations.
