Ray & Paula
- Apr 11, 2008
Hi,
I'm about to purchase an LCD monitor and LCD TV for video editing. The monitor I am looking at is a Samsung 2253BW 22" LCD and the
TV is a Samsung Series 4 450 LCD. The following is the connections for each;
Samsung 2253BW LCD Monitor
DVI
Analog RGB
Samsung Series 4 450 LCD TV
1 HDMI (HD Multimedia) Interface rear
Component video: 1 (Y, Pb, Pr)
A/V inputs: rear
S-Video Input: rear
RF antenna input: rear
Headphone jack: rear
PC D-sub: rear
I want to use the LCD TV for viewing during editing in order to get the colors as close as possible for final dvd burning. My videos are primarily used for SD and HD television.
My question is connectivity. Will the Nvidia Quadro FX3700 accomodate both the monitor and TV with the connections shown above? This card has Two Dual-Link DVI Output Ports. Would I need a certain type of cable for connecting to the TV? If so, please give me the info needed for the correct cords to use.
As you can see I'm a little ignorant when it comes to the connectivity, but I want to make sure I get the right card to accomodate this monitor and TV. Your help will be most appreciated! Thank you, Ray
DVI
Analog RGB
A/V inputs: rear
S-Video Input: rear
PC D-sub: rear
