I've recently switched all my hard-ware over to an HTCP case, and I'm going to be doing some major rebuilding and modding on my old aspire x-qpack, that's already been hacked a bit (used to be watercooled).
I got an old lomita celeron board from a pavilion 511n from a friend of mine, which I am going to use.
My goal in all of this is not to make a fancy powerfull rig (the mb doesn't even have a pci-e or agp slot, just 3 pci slots) but rather to make a small portable good looking computer that is silent, well cooled, small and unique.
Time for some pics!
This is the xqpack chasis. You can see that it had been cut a bit, one for a dual 80mm radiator, the other for a 60 mm fan that helped cool the hard drives. This case is going to get hacked.
This is the motherboard in question. I added two ram sinks (right) and a cooler over the NB and SB using the superglue / thermal paste method. It may or may not make any difference whatsoever, I'm not even sure that there is any substantial amount of heat put out by these chips, but I had the extra heat sinks, so I figured might as well put them to some use. I have 3 pci slots to work with, usb 1.1, 512mb sdram (thats the max), the celeron 1.3GHz, onboard intel video and some random 2 chanel sound.
I also have an older small form hirpo 160W psu that's going to be powering everything. 160W should be plenty for the limited stuff thats going into this box. I've swapped out the fan on this psu (noisy) for a blue led 80mm fan that i tore out of the crappy xpack psu.
I have some black sleeving left over that will go on the wires (after I get a molex removal tool).
More to come soon!
Time for some pics!
More to come soon!
