user_green
- May 28, 2018
Hi,
I cracked my hp 640 g2 display, model HB140wx1-401.
I found in my country a good price for a similar display, model LTN140KT14-201.
The original was 1366x768, and the one i found is 1600x900. The specifications says both are single lane edp.
Could you please confirm if the second display should work fine on my machine?
Here is a comparing of the two:
http://www.panelook.com/modelcompare.php?ids=25623,21645
Thank you!
Thank you!
