Not recognizing EVGA GeForce 460
natr89
Hey guys,
I have a EVGA GeForce GTX460 1GB DDR5 PCI-E 2.0 Graphics Card
This is the specs for the rest of my system:
Cooler master centurion case – with the chassis for more drives. http://www.newegg.com/Product/Produ...ooler_master_centurion-_-11-119-047-_-Product
Core 2 Duo E6600 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819116347&cm_re=e6600-_-19-116-347-_-Product
Scythe Mine Cooler - http://www.newegg.com/Product/Produ...5166&cm_re=scythe_mine-_-35-185-166-_-Product
4GB Corsair XMS2 - http://www.newegg.com/Product/Produ...cm_re=4GB_corsair_ddr2-_-20-145-184-_-Product
Asus P5B Deluxe with Wifi - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131028
DVDRW
Antec TPii – 550w - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371020&Tpk=antec tp ii 550
When I put the card in, nothing comes up. It powers correctly, but nothing shows on the screen. Is it not compatible? Please help.
I get one long beep followed by 3 short beeps after booting up. Fan on card runs fine. Everything seems to be running great as far as power, but i never get a signal on the monitor. Help?
Do you have another system that you can swap things in and out of to test?
No I do not. I do not have anything with a power supply that can run this card. I have a bunch of old comps in my garage, but to my knowledge, they all just have stock power supply's and mobos (Dell).
