Not enought power?
Status
Not open for further replies.
Farva
Extremely [H]
ok i have an antec 300W (almost 4 years old) powering:
amd xp 2800 @ 2.3ghz
thermalright alx-800
vantec tornado (84.1cfms)
vantec 3.5" fan controller
asus a7n8x-x
1.5GB kingston ddr400
ati 9600 pro 128mb
sound blast audigy es
netgear 10/100
WD promise card
sony cd-rom
sony dvd-rom
WD 80gb ata 7200 rpm
seagate 80gb ata 7200 rpm
WD 160 gb ata 7200 rpm
problem is my system would reboot and i would get no blue screens of death. im think i am running out of power. any thoughts?
Install motherboard monitor and see if your voltages are low. Hell another way to see if you are gettnig enough juice is unplug most of that stuff and see what happens.
If you are rebooting with BSOD's when is the last time you ran memtest86?
i know the first stick of 512 is good, the other 2 i just got from newegg last week. i have not gotten any BSODs. it seems to be running ok. i turned off auto reboot when there is a system failure.
RAM can also cause systems to reboot, mine and my bro in laws did that because of bad RAM. Just go ahead and run the test, that way you can rule it out.
PSU was bad and processor took a dive a few months later. Everything else was fine.
Status
