not booting after sleeving...
boardsportsrule
ok, so i went and sleeved my psu....first time i screwed up, but i didnt even plug it in before realizing it so i took em on out and re did it.... now when i plug it back in i get some WIERDDDDDDD stuff happeneing...ok with the 24 pin and the molex and the floppy i get solid lights but no boot....with the 24 pin and the 4 pin i get a flash on and flash off.... im stumped...i've checked the wires many times...off to check one last time then go find a nice tall cliff to jump off and end this all ... any idea's people??
__________________
Dfi NF4 UT ultra-d
3200+ winchester
zalman 7700-cu
6600gt with zalman 700-cu
seasonic 500 watt PSU
200gb seagate 7200.8
cd-rw drive, and a dvd-rw drive.
turtle beach sound card
2X512 pc4000 redline
5-10 bios
make sure that you didn’t cut any wires for starters...You could also try cleaning out the power connector on the motherboard with an air duster (AKA "Canned Air" :p )
Sounds like you didn't slide the sleaving over the connectors, but had removed the pins and then repined the connectors after placing the sleaving back on, right?
Yikes, if the voltages went to the wrong place on your 24 pin connector, you coulda damaged your system good. :eek: If you have access to a supply that hasn't been modded in this manner yet, it may be a good idea to test with it and make sure nothings damaged hardware wise.
Once this has been confirmed, I'd very carefully and painstakingly make sure that every wire is in it's proper place. Hopefully your PSU manual shows a very acurate pinout that you can follow to ensure things are copesthetic.
I've found that while it takes a little work, I've yet had a need to remove the connector to fit the sleaving material on (including the 24pin connector, just had to bend it inline with the wires temporarily).
Let me know if I'm off target. I'll also see if I can find you a link to the pin outs if you require it.
Good luck. :)
unknown, ill check to make sure no wires were cut... good idea..
high, yes, all you said was correct...i've checked all pins to online things, what i wrote down AND other psu's....SOO yea, all the pins are correct....arrr!! :S
