Northbridge Fan Sound
Cr0boss
Hey,
I own a 790i ultra sli motherboard and notice the north bridge fan is louder than everything in my PC. When I unplug it my PC becomes silent. I was wondering if anyone has some good alternatives or knows of any good fans to counter this.
Thank you,
Cr0
water cooling lol nah jk i have the 780i same issue with mine... in my case i am running WC so i plan on just using that to subsequent the noise and give for more optimal cooling... no i dont OC but i also dont like the idea of anything being controlled by something mounted at a 45 degree angle on a bearing that has tendencies to fail...
but i know that koolance and cooler master sell just north or southbridge heat sinks w/ fans.. only issue is what will cool your mosfets/memory that is attached to the stock heat sink and fan.
to be honest i have no idea ... maybe contact the manufacturer for a new fan as yours is too noisy... mine isnt super loud but just about the same as the exhaust fan which is supposedly only 12db.
could be a dud?
Put it on a fan controller and make sure you have good airflow. Problem solved.
Or get an aftermarket tower HS like an HR IFX from Thermalright.
problem is that fan needs to run in order to cool the motherboard memory, mosfets, norht and southbridge as it is all one piece.. slowing down the speed could raise temps a little bit too much. and as we know heat and static are the #1 killer for electronics.. well besides water.
That puny chipset fan doesn't stand a chance to a quiet 120mm Gentle Typhoon pointed right at the motherboard.
You can take it off and still have lower temperatures if you have good case cooling.
