Northbridge fan problem
Jap1987
Just recently my KN8 ultra's Northbridge fan started to make grinding sounds so I unplugged it. I have a 80mm fan pointed in the general direction to keep some heat off, but I was wondering if I should replace this fan. Right now the temps idle at 26C. How much can these chips take.
I did exactly the same as you for over a year with my last PC.
Remove the heatsinks fan and just keep the heatsink in place with the larger fan circulating air.
If it worries you buy a fanless heatsink replacement.
I just wanted to make sure someone else did it.
Thanks for the fast response.
my friends asus a8nsli dlx's nothbridge fan just quit and he did nothing about it. Still works ok for him for about 6 months now.
