So just put together a machine with an i920 and used the liquid cooling parts I had from my previous build (a long time ago) and had a few questions regarding what kind of temps I'm seeing.
Currently I'm at stock speeds (2.66 @ x20, 2.79 @x21) and wanted to make sure everything is working right before I start to OC the thing.
Tool I'm using to test:
My questions:
HW Monitor shows a few different temperature regarding the CPU; it shows the "CPU Temp" are reported by the motherboard, and the temp for the individual cores as reported by the chip itself. Which temp(s) do I care about?
Although I know they mean nothing, at idle my CPU temp is ~30C (+/- 2C) and my Core Temps are between 40C and 44C. My VREG temp idles at around 45C. Are these numbers normal?
When I load it up using IntelBurnTest (8 threads, max RAM) my CPU temp is around 50-52C and my core temps are 65-67C. The VREG temp seems to top out around 64-66C as well. Ambient is 24-26C. Again, are these temps normal?
Once I stop the test the CPU temp drops almost instantly to 33C but the core temps take a few minutes to drop down to 45C.
My goal isn't to push the chip to it's limit, but get a decent overclock while still keeping it relatively quiet.
Other info:
Enzotech Luna.RevA Waterblock
DD12V-D5 water pump, set at max speed (http://www.dangerden.com/store/dd12v-d5_pump-variable-speed-by-laing.html?&cat=23)
Danger Den 120x2 radiator (don't reember specific model number)
RAM is running at 1600MHz at 1.65V.
If there's any other info that would be help, just ask.
CPUID HW Monitor v1.14.0
IntelBurnTest v2.3
My questions:
Other info:
using the two 120mm fans that came with it (they run at 1100rpm but I don't know how many CFM they move)
Using stock intake fan (HDD mount) and 230mm side intake fan. Added an extra exhaust fan above the io-plate.RAM is running at 1600MHz at 1.65V.
