A Great friend to the HardForum with a great kid that he is trying to get a scholorship to continue his schooling. Please give hime a vote! Only 24 hours left! Thanks.
yea, somewhere around here is a "NET something something" command line command you could just write little batch files and add these to XP scheduled tasks I think
Just make sure you get the path correct for these. If you've installed F@H in a different directory, your commands will be different from those. The most reliable way to get the name is to go into the services administration console and do properties on the F@H service and grab the display name line, which you can then copy and paste into the quotes. One other thing to keep in mind is that these commands only work in XP and not in 2k for some reason.
Also, I believe there has been some talk of adding those lines into a users login and logout batch files so you could have folding run whenever someone isn't logged in.
