I have 2 sata ports on my mobo, one is being used by my current HD. I just ordered a second one and I was wondering if there's such thing as primary/secondary sata ports? Or are they all the same, doesn't matter which I plug the new HD into (I want the new HD to be the "main" HD)
Do I just need to set the boot order in bios and that's it?
Second question: My new HD is a 3.0 sata but my motherboard only supports 1.5
Do I need to do something with the jumpers or is that not necessary? Should just be able to work right out of the box?
