noisy !!!
TSUNAMI (thermaltake case ) three stock funs - 2 (120mm) and 1( 80 mm)
FX-55 - ( artic cooling freezer 64 pro ) extemely quite
POV 6800 ultra - removed stock fun -- placed zalman fatality
asus A8N deluxe motherboard -- ( had a problem with the original fan contacted asus and replaced it with a new one )
my problem is that one of my friend owns a soprano case which is exactly the same as mine except that it is blac and u can barely hear his computer . of course he hasnt got an fx-55 or a 6800 ultra . strange but the difference is a lot . do u think that little fun of the chipset fun makes that difference . im thinking of replacing it but dont want to put a fanless heatsink . idont trust it . please help me
the fatality is probly making a bunch of the noise. Those suckers are LOUD, cuz they are more about high-performance than quietness.
Unless you have a bad fan, it ain't the case...my Tsunami is very nicely quiet. The hard drives are louder in mine.....
FATality cooling fan seems to be a culprit....
