Noise
JS_
I recently bought a 4890 video card. For me it seems a bit noisy compaired to what i came from (8800GTS).
Would a GTX 275 be a quieter card than a 4890?
It seems different review sites have different opinions on how loud each card is.
thanks
you could always get an aftermarket cooler like arctic twin turbo
thanks
Yes... I believe so.
I have seen it posted that ATI at 80%, sounds like Nvidia at 100% fan speed.
I haven't had an ATI card myself, so get more input. ;)
Check this thread...
http://www.hardforum.com/showthread.php?t=1401866
That is an option, but if you have a better, slightly more expensive that's quiet (perhaps using a non-reference design, perhaps just a well designed card), wouldn't it be better to go with that rather than wasting money buying a cheaper card then paying for an aftermarket cooler? ;)
Point being, sure, you can use aftermarket coolers to make a card quiet, but you get better bang for your buck if you can just buy a quiet card to start with.
