Darth Bobo
- Jan 6, 2007
Hi all,
I have begun researching parts for a SFF build within the next few months.
Now I hope to transition the system to the Kimera Industries Nova once it's available, but until then I plan to build in the Fractal Design Node 304.
This obviously limits me to mini-ITX motherboards and I'm targeting the Asus Impact VII and I a full size GPU (probably a GTX 970).
The Questions are:
I want to cool the CPU with a 120mm push-pull AIO configuration (Corsair H80i GT) as I cannot fit a 240mm solution in the Node. Will this also fit the Nova? I'm pretty sure it will if I loose one of the fans (thick rad).
What to do with the PSU? I would very much like to go modular, but I cannot for the life of me find a modular PSU thats 140mm in length and will allow me to put a full size GPU in the Node, I believe the same issue is present in the Nova. What PSU's are people putting in their Node 304s?
Thanks for any input in advance, especially related to the PSU question as that is what's nagging me the most.
The Questions are:
