No POST....I'm going insane.
Howdy
Ok , this will sound very ignorant.
I recently installed Heat spreaders on my RAM, while putting them in i accidentally put in one of them backwards, how the hell i did this i do not know, never done this before.
Somehow the ram went in backwards very easily, even with the small notch in in giving the direction it is to fit. So i try and boot no go, i turn it around this time it kinda boots.
No POST at all my pretty cathodes come on and all fans, no picture. no post, and my pc will not shut off unless i unplug it. I tried reseating my ram still no go. my mainboard is an MSI854E 533mhz fsb. Any help in this would be great.
You installed your RAM backwards?
I saw someone do that once before--he pushed the memory down and somehow got it to clip into place while bending the motherboard and memory slot down in the middle. It fried his RAM and motherboard. You may want to check the pins on your memory sticks and look for any burned looking components. Check the motherboard too.
If all you did was install the heat spreaker backwards, then you're probably fine. I would try taking out the DIMM you installed wrong and see if the computer will post with just the other stick in there. You may also want to try putting the RAM into different slots.
I admit that I did this once. Take the RAM out of that slot and never use that slot again. Reset your CMOS and only install RAM in the other slots and your board may still work.
Well, this worked.............. my mobo only has 2 dimm slots and if i leave the one i put in backwards out i can only have 512megs so looks like i will need to buy a new mobo, oh well at least its not the worst that could happen.
After more testing it came out to only be that the ram installed backwards is now ruined, so no new mobo THANK you guys for replying and reminding me of other options. thank you so much.
